Старый 29.03.2011, 19:12   #1
palleagermark: Run the Microsoft Dynamics® AX 2012 Hyper-V pre-release image without a Hyper-V server
Источник: http://palleagermark.blogspot.com/20...2-hyper-v.html
With the latest version of VirtualBox from Oracle, you can run Hyper-V images from a PC without Windows Server 2008 R2 Hyper-V - for example a box with Windows 7.
There are a few special things you must do in order to make the Dynamics 2012 image work with VirtualBox:
  • Setup the disks as IDE disks. It won't work as SATA disks.
  • Setup two network cards:
  • - Adapter 1 should be configured for "NAT"
  • - Adapter 2 should be configured for "Internal Network"
When the virtual server is started you need to change the TCP/IPv4 network setting for the first adapter:
  • Select "Use the following IP address"
  • IP address: 192.168.0.1
  • Subnet mask: 255.255.255.0
  • Select "Use the following DNS server addresses"
  • Preferred DNS server: 192.168.0.1
I'm not too sure about the network card settings, as to why they have to be configured like this, but this configuration works and resemble the Hyper-V settings as closely as I could figure it out. If anyone has some actual knowledge about this, I'd love to hear about it.
I have tried the image with only 2 GB of RAM for the virtual server. It runs (except for Enterprise Portal), albeit very slow. 4 GB or more gives you a more acceptable performance.
Check the license requirements for VirtualBox. In most cases it is free. But if you, for example, roll it out as part of your business operations you might have to buy a license.
Please share your experiences running the image this way.
Oh - and the Dynamics AX 2012 image itself!? Well, if you don't have it already - you're unfortunately not eligible to get it yet and you'll have to wait for coming releases.
За это сообщение автора поблагодарили: wojzeh (1).
Старый 06.05.2011, 07:25   #2
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
Аватар для TasmanianDevil
887 / 389 (14) ++++++
Кто-нибудь это шаманство пробовал ?
Старый 06.05.2011, 10:36   #3
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
По крайней мере диски из под virtual pc не совместимы.
А Hyper-v и virtual pc совместимы.
Axapta book for developer
Старый 06.05.2011, 12:11   #4
TasmanianDevil
Мрачный тип
Я имею ввиду именно с упомянутым здесь продуктом от Oracle получилось запустить или нет?
Т.е. машинку виртуальную настроить, диски присобачить, загрузить и пощупать бету 2012
У меня первоначальную загрузку проходит (прогресс с надписью "Windows is loading files" пробегается), потом как будто reset нажали и по новой.
Как-то привык жить с VirtualPC, все эти новомодные гламурные изыски типа Hyper-V мимо прошли - чувствую себя пень пнем.
Последний раз редактировалось TasmanianDevil; 06.05.2011 в 12:16.
Старый 06.05.2011, 13:06   #5
Mykola Galak is offline
Mykola Galak
У меня работает.
Экстеншин пак установлен на VirtualBox?
Старый 06.05.2011, 13:20   #6
TasmanianDevil
Мрачный тип
Сообщение от Mykola Galak Посмотреть сообщение
У меня работает.
На какой базовой и какой гостевой ОС запускаете ?
Не стоял, скачал-поставил - картина как-то без изменений
Старый 06.05.2011, 13:41   #7
Mykola Galak
Win2008 x64
Старый 06.05.2011, 13:55   #8
Daiver is offline
Daiver
177 / 44 (2) +++
Диски подключили к IDE контролеру в виртуалке?
Старый 06.05.2011, 14:14   #9
TasmanianDevil
Мрачный тип
Win2008 x64
Похоже, что все дело в том, что рабочая машинка у меня престарелая уже и не тянет все фичи виртуализации - Core2 под XP. Попробую на домашней еще запустить ...
2Daiver
Да, именно к IDE-контроллеру
Старый 16.07.2011, 00:54   #10
wojzeh is offline
wojzeh
Аватар для wojzeh
681 / 517 (19) +++++++
работает
Felix nihil admirari
dynamics-community.at: Discontinuation announcement: Oracle Datenbank Support in Microsoft Dynamics AX 2012 Blog bot DAX auf Deutsch 0 25.01.2011 22:11
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Dynamics AX: Managing Your Supply Chain Using Microsoft Dynamics AX 2009 - Book Review Blog bot DAX Blogs 0 31.03.2009 23:06
AX UK: Pre-Sales Demonstration Toolkit For Microsoft Dynamics AX 2009 - Refresh 1 - Available now Blog bot DAX Blogs 0 24.02.2009 18:05
Часовой пояс GMT +3, время: 23:17.
