Старый 03.07.2011, 18:13   #1
palleagermark: Find you SID
Источник: http://palleagermark.blogspot.com/20...d-you-sid.html
If you restore the demodatabase for an AX 2012 image, you might need to know you SID in order to change your login in the AX database.
This script displays your SID and copies it to your clipboard:
Код:
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set objAccount = objWMIService.Get _
("Win32_UserAccount.Name='Administrator',Domain='corp'")
Wscript.Echo objAccount.SID
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run "cmd.exe /c echo " + objAccount.SID + " | clip", 0, TRUE
Wscript.Echo "Your SID is copied to the  clipboard"
You may need to change the values for the user account name and the domain.
And this is the script you can use in the database:
Код:
update userinfo
set
networkdomain = 'YourDomain',
networkalias = 'YourAlias',
SID = 'YourSID'
where ID = 'Admin'
Последний раз редактировалось Poleax; 04.07.2011 в 21:20. Причина: оформление
Все о Microsoft Dynamics CRM: Включение неактивных записей в результат Быстрого поиска (Quick Find) в Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 26.07.2009 22:06
palleagermark: formdatasource.research(TRUE) Blog bot DAX Blogs 0 26.05.2009 01:10
To find objects in AOT with particular properties Blog bot DAX Blogs 1 26.04.2008 07:33
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Часовой пояс GMT +3, время: 10:59.
