Старый 06.12.2010, 23:11   #1
sumitax: Upgrading SharePoint 2007 Web controls to SharePoint Server 2010
Источник: http://sumitax.wordpress.com/2010/12...t-server-2010/
While upgrading web controls to SharePoint 2010 , we found a issue with Sharepoint Dll in web controls  even  though Sharepoint and related Dlls are present in Assembly directory (C:\Windows\Assembly)
ERROR: Could not load file or assembly ‘Microsoft.SharePoint.ApplicationPages, Version=12.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c’ or one of its dependencies. Access is denied.
Solution:
You can go to the project properties page (can be accessed from the Project pull down menu), going to the references tab, and adding the path to the  Microsoft.SharePoint dll ( Browse the Dll under the Assembly folder)
Ошибка после установки - AX40SP2FP1EE natterru DAX: Администрирование 13 03.09.2010 09:53
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Часовой пояс GMT +3, время: 17:55.
