Старый 14.11.2010, 10:18   #1
Preston.Larimer: Item import from CSV file made easy (Kinda)
Источник: http://palarimer.greenlight2go.com/2...made-easy.html
The job below uses the axInventTable class to create items from a CSV file. We gave the client an Excel file with columns identified for them to fill in for new items they wanted then saved that without the header to a CSV file. This job reads in a CSV file then uses the axInventTable class to create the new Item. The axInventTable class manages all related tables for us. If you look at the code below, you can see through this class we can easily set values in the related tables as well as the main inventTable record. In the below job you can see we used a mix of values read from the file, and values hard coded, you can easily add fields to your import file to incorporate into the creation of your item as you need them.
One thing to be aware of is if Item templates exist AX will try to find the default Item template to use when it does the initialization of the tables. If there is not a default template it will use the first template found. This is easy enough to work around, just create a new item with minimal fields set and make a template from that item and set it as default using the SysRecordTemplateTable form.
Note: As a side note Atlas 4.0 appears makes use of a similar process for item imports and has the same issue with the Item Template described above.
//-JobStart -->
static void GL_ItemImport(Args _args)
    axInventTable axInventTable;
    inventTable inventTable;
    itemID itemID;
    textBuffer tb = new textBuffer();
    int cnt;
    int numLines;
    int c;
    container inLine;
    Dimension finDim;
    itemType ItemType;
    tb.fromFile('C:\\items.txt');  //File name  with Path ...
    numLines = tb.numLines();
    if(numLines)
        for(cnt = 0; cnt < numLines; ++cnt)
            inLine = str2Con(tb.nextToken(true));
            if(conpeek(inLine, 1))  //first field item ID don’t do anything if blank ....
                axInventTable =  new axInventTable();
                axInventTable.parmItemId(conPeek(inLine, 1));
                axInventTable.parmItemName(conPeek(inLine, 2));
                axInventTable.parmNameAlias(conPeek(inLine, 3));
                axInventTable.parmItemGroupId(conPeek(inLine, 4));
                axInventtable.parmItemType(str2enum(ItemType, conPeek(inLine, 5)));
                axInventTable.parmModelGroupId(conPeek(inLine, 6));
                axInventTable.parmDimGroupId(conPeek(inLine, 7));
                axInventTable.axInventTableModule_Sales().parmTaxItemGroupId(conPeek(inLine, 13));
                axInventTable.parmPrimaryVendorId(conPeek(inLine, 14));
                axInventTable.axInventTableModule_Purch().parmPrice(ConPeek(inLine, 15));
                //Set financial dimension
                finDim[2] = conPeek(inLine, 18);
                axInventTable.parmDimension(finDim);
                axInventTable.axInventTableModule_Purch().parmUnitId(conPeek(inLine, 20));
                axInventTable.axInventTableModule_Sales().parmUnitId(conPeek(inLine, 21));
                axInventTable.axInventTableModule_Invent().parmUnitId(conPeek(inLine, 22));
                axInventTable.parmPackagingGroupId('TMP');
                axInventTable.parmBOMUnitId(conPeek(inLine, 22));
                axInventTable.axInventTableModule_Invent().parmOverDeliveryPct(20);
                axInventTable.axInventTableModule_Invent().parmUnderDeliveryPct(20);
                axInventTable.axInventTableModule_Sales().parmOverDeliveryPct(20);
                axInventTable.axInventTableModule_Sales().parmUnderDeliveryPct(20);
                axInventTable.axInventTableModule_Purch().parmOverDeliveryPct(20);
                axInventTable.axInventTableModule_Purch().parmUnderDeliveryPct(20);
                axInventTable.save();
                ++c;
        info(strFmt('Imported %1 Items', c));
//-Job End <--
ax2009, axbc, импорт данных
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Import Consolidation from File <Attain> uk NAV: Программирование 1 26.03.2004 17:13
Часовой пояс GMT +3, время: 07:41.
