Старый 22.09.2010, 02:08   #1
dynamicsaxtraining: The cursor is invalid for instantiating recordViewCache
Источник: http://www.dynamicsaxtraining.com/ti...ecordviewcache
If you receive the “The cursor is invalid for instantiating recordViewCache” message then try to move your method in the server side.
For example if you have class that extend RunBaseBatch then create runOnServer() method and move all code from the run() method to the runOnServer() method.
void run(){ ; ClassName::runOnServer();}static server void runOnServer(){ //code from the run() method}
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
dynamicsaxtraining: Create new company. Demo data Blog bot DAX Blogs 0 19.11.2009 14:05
dynamicsaxtraining: Item setup: Item group Blog bot DAX Blogs 0 12.11.2009 17:05
Часовой пояс GMT +3, время: 16:22.
