Старый 12.07.2010, 09:05   #1
kamalblogs: Refreshing AIF service classes in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
When you are frequently working with  AIF integration, there are chances that your classid’s for the AIF class could change when you import as XPO without id’s in another test or development machine repeatedly.
This can create a problematic situation where Ax will fail to recognize the same integration class with different Id. The simple reason is that most of them rely on the class Id to generate the related services. To get out of this situation you should try these steps’s suggest by Pawan.
Refer to the link below…
http://pawansaxblog.blogspot.com/201...hemastore.html
kamalblogs: Running AIF without Active directory in Dynamics Ax Blog bot DAX Blogs 0 19.04.2010 09:05
Dynamics AX: WCF: The Enterprise Service Bus for Dynamics AX and the rest of the Microsoft Stack Blog bot DAX Blogs 0 10.03.2009 16:05
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 10:17.
