Старый 09.06.2010, 16:05   #1
gustafwesterlund: How to remove a windows service
Источник: http://gustafwesterlund.blogspot.com...s-service.html
Today I needed to reinstall CRM on a VPC and for some reason the Async Service wasn't unregistered properly. When I tried uninstalling it using installutil with the following command:
"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\installutil" /u "C:\Program Files\Microsoft Dynamics CRM\Server\bin\CrmAsyncService.exe"
it couldn't find the file. Seemingly, the uninstaller had a job half way and removed the file but not unregistering it as a service. So, how to uninstall? Looking around a bit I found the following command did exactly this:
sc delete MSCRMAsyncService
Good to know, if needed.
Gustaf Westerlund
Microsoft Dynamics CRM Chief Architect
Logica
www.logica.com
gustafwesterlund: Reporting Services Windows Service wouldn't start Blog bot Dynamics CRM: Blogs 0 01.03.2010 16:05
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 21:27.
