Старый 16.01.2010, 04:22   #1
AXDevCenter Headlines: Application Benchmarking Toolkit Released
Источник: http://services.social.microsoft.com...BJYzodxCp3c%3d
The Application Benchmarking Toolkit for Microsoft Dynamics AX 2009 enables you simulate user activity on your installation and use the Microsoft Visual Studio Load Test software to run stress and performance tests. The toolkit comes with a set of pre-defined scenarios as well as a programming model proxy that generates C# code that uses the .NET Business Connector to make calls to X++ application code.
Microsoft DAX Dev Center Headlines: AX 2009 Documentation White Paper Released Blog bot DAX Blogs 0 14.11.2009 03:10
Microsoft DAX Dev Center Headlines: Fleet Management Code Sample for Dynamics AX 2009 Released Blog bot DAX Blogs 0 04.09.2009 01:06
Dynamics AX: Application Benchmark Toolkit for Dynamics AX 2009 - Released Blog bot DAX Blogs 0 26.03.2009 01:08
axperf: Application Benchmark Toolkit for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 1 18.03.2009 13:47
Microsoft DAX Dev Center Headlines: New Ledger Posting White Paper Released Blog bot DAX Blogs 0 23.11.2008 12:05
Часовой пояс GMT +3, время: 14:53.
