Старый 16.11.2009, 11:05   #1
DeniZone: Deleting duplicate records in SQL
Источник: http://denizone.blogspot.com/2009/11...ds-in-sql.html
Recently I needed to delete some duplicate records across several companies in AX. The table is self-contained so I needn't worry about delete actions or validation and as there are several companies I wanted to try and do it SQL-style. So this is what I came up with
DELETE FROM [Table with Duplicates]
WHERE [Primary Key Field] IN
SELECT a.[Primary Key Field]
FROM [Table with Duplicates] a,
[Table with Duplicates] b
WHERE a.[Primary Key Field]!= b.[Primary Key Field] -- i.e. Userkey
AND a.[Value to check]= b.[Value to Check] -- i.e. Lastname
AND a.[Second Value to Check] = b.[Second Value to Check] -- i.e. Firstname
AND a.[Primary Key Field] < b.[Primary Key Field] -- i.e. Userkey
Respect to the original poster at SQL Server forum.
Remember always to backup your data and try the SQL-statement on a test table before you do anything on data which will be used in live environments.
Microsoft Dynamics CRM Team Blog: Leveraging bulk delete jobs to manage System Job log records Blog bot Dynamics CRM: Blogs 0 13.11.2008 22:06
Мир CRM: Новости об одной из составляющих работы Dynamics CRM - Microsoft SQL Server Blog bot Dynamics CRM: Blogs 0 03.11.2008 06:18
Microsoft Dynamics CRM Team Blog: Accessing a SQL Database from a Microsoft Dynamics CRM Plug-in Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Dynamics AX: SQL Server, Heart of Dynamics AX Blog bot DAX Blogs 0 13.07.2007 18:00
Axapta Lessons: Merge Customer Records Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 13:46.
