Старый 25.09.2009, 16:05   #1
mfp: Introducing AX models - Part 1
Источник: http://blogs.msdn.com/mfp/archive/20...ls-part-1.aspx
About a milestone ago I announced SQL AOD. Since then it has been quite quiet on my blog - for two reasons 1) I've been heads down in new features and 2) I've been on paternity leave. Now the completion of M2, the next milestone of AX "6", is within reach and I've returned to my office. This means I can share some more exciting news.
Since the days of AOD files are numbered we need a new vehicle for deploying metadata elements to an AX installation. To address this need we introduce Models. A model is a containment of metadata elements.
To create a model you use the new command line utility AxUtil:
AxUtil create /model:"My Model" /Layer:USR
This will create a new model with the name "My Model" in the USR layer. This new model can be selected in the AX client configuration utility as the default model. When you start AX the status bar will tell you which model you are currently working in - just next to where the current layer is shown. When you make changes in the AOT, like overlayering elements, creating new elements, changing X++ code etc., the resulting elements will automaticaly be contained in your model.
When you have completed all your changes, then your model is complete. In other words it is time to move the model from your developer box to a production system. In AX2009 you would copy your AOD files - with models you need to export it to a physical file. Again you will use AxUtil:
AxUtil export /model:"My Model" /file:MyModel.axmodel
Now you can copy this file to the production system and import it there:
AxUtil import /file:MyModel.axmodel
You can even uninstall it again - if that is what you want. This is semantically the same as deleting an AOD file in AX2009:
AxUtil delete /model:"My Model"
So far I have described the model capabilities that gives parity with AOD files: We have a file based container that can be xcopy deployed and we can delete models again.
From what I've described so far models aren't much different than layers and AOD files. They are; and provide some highly desirable capabilities - which will be the topic of a near-future post - so stay tuned.
слой приложения, sql
Dynamics AX: Business Intelligence in Dynamics AX 2009 (Part I) Blog bot DAX Blogs 0 26.06.2008 02:19
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Dynamics AX: Dynamics AX - "Snap to it!" - Part I Blog bot DAX Blogs 0 01.12.2006 21:40
Часовой пояс GMT +3, время: 08:47.
