Старый 15.08.2008, 04:15   #1
Method Overloading
Источник: http://alexvoy.blogspot.com/2008/08/...erloading.html
Sometimes we need to change the standard behaviour of form controls. It is not a big deal when when it concerns overriding form controls' methods in design time in AOT. But when it comes to doing that dynamically it may not be as simple as a piece of cake.
From the beginning the goal was to make sorting functionality on the grid created by SysTableLookup class impossible for the user. It might have been a good solution to change the code like the following
formRun = classfactory.formRunClass(args);
form = formRun.form();
// allow the class to react on the form's events
formRun.controlMethodOverload(true);
formRun.controlMethodOverloadObject(this);
// here override Sorting on all datafields added on the grid
this.overrideSortMethodOnDatafields(form);
<span class="rem">//
DeniZone: Invoking a method on a field in a form's datasource Blog bot DAX Blogs 0 13.02.2009 14:05
axaptafreak: Catching keystrokes and the task() method Blog bot DAX Blogs 0 30.10.2007 17:10
Sample Design Patterns: SysDictClass method implementedBy() returns as if class implements itself Blog bot DAX Blogs 0 25.10.2007 05:44
axaptapedia: Display method Blog bot DAX Blogs 0 29.08.2007 16:30
Часовой пояс GMT +3, время: 23:59.
