Старый 13.11.2007, 02:25   #1
Dynamics AX: LINQ, C# 3.0 - Something looks familiar
Источник: http://dynamics-ax.blogspot.com/2007...-familiar.html
Well I actually, finely, took a little time and looked at a good article on LINQ and how it will be used in C# 3.0. And in doing so, the concept, how it interacts with the CLR and data, it looks VERY similar to something us X++ folks have been doing for nearly 8 years now... working with a data model, and data model variables for tables, and using SQL Like Statements within X++ to fill and work with those variables, which represent table objects from a database.
I mean you can't blame them, in fact I am SO glad they are finally, really getting to the point to where LINQ will be close to what X++ can offer. Of course it's not as knowledgeable as X++ is, but then a Object Tree would need to exist for the C# application, in order to make use of it... *gears spinning*
I can see how this move, and the sure to be robust LINQ is paving the way for X++ and Dynamics AX to be developed from Visual Studio, and a native .Net application. I would like to see how the Object Tree, labels, and the layering is handled though. Still, for those of us that develop in C# when X++ is not the language this is such a wonderful new technology for working with XML, Object, and Data, that brings C# closer to what X++ offers us!
Check out the direct link this post header points to on MSDN, and Check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Старый 13.11.2007, 11:33   #3
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
А вот здесь
http://msdn.microsoft.com/msdnmag/is...lt.aspx?loc=ru
и по русски можно почитать
Последний раз редактировалось MikeR; 13.11.2007 в 11:34. Причина: баг
Старый 13.11.2007, 12:13   #4
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Трассировщик лучей на LINQ:
LukeH's WebLog : Taking LINQ to Objects to Extremes: A fully LINQified RayTracer
Старый 13.11.2007, 14:30   #5
Morpheus is offline
Morpheus
Аватар для Morpheus
602 / 167 (7) ++++++
В J2EE это уже давно реализовано!
Старый 13.11.2007, 14:41   #6
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
Сообщение от Morpheus Посмотреть сообщение
Ссылку, плиз
Dynamics AX: Why Dynamics AX beats SAP Blog bot DAX Blogs 0 10.01.2007 23:15
Часовой пояс GMT +3, время: 03:24.
