Старый 27.08.2007, 22:10   #1
casperkamal: Preventing a form getting added to "LastActivated Form" in Dynamics Ax
Источник: http://casperkamal.spaces.live.com/B...CD63!325.entry
The Class "Infolog" has few methods corresponding to "Last activated form" like
                       - activate
                      -  setLastActivatedForm
                      -  parmLastActivatedForm
                      -  close
     These methods help in you knowing, setting or getting the currently active form.
       Say you have a form like "Toolbar" or  "Popup" form like Alerts or "Find" then you would prefer to prevent these form from being added to the lastactivated form. In such cases all you have to do is go to the "activate" method in infolog and add the following code
    if (formRun.name() != formstr(DocuView) &&
        formRun.name() != formstr(sysFormSearch) &&
        formRun.name() != formstr(EventAttentionGrabber) &&
        //added by kamal
        formRun.name() != formstr(MyForm)
        this.setLastActivatedForm(formRun);
  This would skip adding your form to the last activated form list.
Старый 27.08.2007, 23:17   #2
Вот если б еще кто-то рассказал, какую выгоду я могу из этого извлечь.
gatesasbait: "Go to the Main Table Form" differences between Axapta 2.x and Dynamics AX 4 Blog bot DAX Blogs 0 12.08.2008 19:05
casperkamal: A simple "Toolbar" for Dynamics Ax 4.0 Blog bot DAX Blogs 9 29.03.2007 13:18
casperkamal: InventDim id blank from "Axapta" to "AllBlank" in Dynamics Ax Blog bot DAX Blogs 4 27.02.2007 10:36
casperkamal: Check out "AxspacesInvader" Game for Dynamics Ax Blog bot DAX Blogs 0 23.02.2007 23:03
Часовой пояс GMT +3, время: 05:58.
