Старый 27.05.2007, 14:21   #1
dynamicsusers: What object belongs to what granule
Источник: http://dynamicsuser.net/blogs/waldo/...t-granule.aspx
I just added 2 spreadsheets to the download section: a Granule List for Dynamics NAV 5.0 and 4.0. You can use the Granule Lists to determine what objects are included in a certain granule, or in what granule a specific object is included, and this way detaermine which granules your customer needs to buy in order to gain access to certain objects. The spreadsheet lets you filter on Granule Numbers, Object Types and Object Numbers. You can find the download here ....(read more)
Dynamics AX: Map Object Sorting - a real issue Blog bot DAX Blogs 7 15.10.2008 12:02
Axapta Lessons: Application Object Id’s Blog bot DAX Blogs 0 27.06.2007 09:30
Dynamics AX: .Net BC, C# - Working with AxaptaRecord Object Blog bot DAX Blogs 0 20.06.2007 23:13
dynamicsusers: Navision and Unicode Blog bot DAX Blogs 0 16.03.2007 12:40
dynamicsusers: IDE extension tools for Dynamics AX Blog bot DAX Blogs 7 13.03.2007 13:44
Часовой пояс GMT +3, время: 02:32.
