Старый 10.11.2006, 01:14   #1
axaptafreak: BREAKPOINT command in X++
Источник: http://axaptafreak.blogspot.com/2006...mand-in-x.html
Hi! I'm back on track and the first thing I want to share after my vacation is a rather undocumented X++ statement: BREAKPOINT
In any X++ line, you can write BREAKPOINT; which will trigger a breakpoint on this line and open the debugger. With that, you could circumvent the fact that Axapta does not know conditional breakpoints and you could write a line like that:
if (i>10)
BREAKPOINT;
I have been using this statement for years, it has been working since Axapta 1.5 (the first version I had).
daxcoder: Conditional Breakpoint Blog bot DAX Blogs 4 25.07.2008 14:47
axaptafreak: Label for query range cannot be modified in AX 5.0 Blog bot DAX Blogs 0 30.08.2007 16:50
axaptafreak: DAX 4.0 Clustering question Blog bot DAX Blogs 0 12.04.2007 16:10
axaptafreak: AOT search within search results Blog bot DAX Blogs 0 16.11.2006 17:40
axaptafreak: Semicolon in classes: another hint Blog bot DAX Blogs 0 10.11.2006 01:14
Часовой пояс GMT +3, время: 05:25.
