Старый 20.03.2023, 01:12   #1
daxrunbase: BACPAC import failure fix
Источник: https://www.daxrunbase.com/2023/03/1...t-failure-fix/
It is a common task to move databases between a Microsoft-managed environment and a self-service machine. From Azure SQL we can only take a BACPAC export, which needs to be imported/converted into Microsoft SQL Server format. With the recent changes and improvements of security, you may be facing an error message when trying to move [...]
The post BACPAC import failure fix appeared first on DAXRunBase.
Rahul Sharma: Dynamics 365 finance database import export operations - bacpac - SqlPackage.exe Blog bot DAX Blogs 0 27.05.2020 19:11
daxrunbase: Hardcoded label fix tool for AX 2012 Blog bot DAX Blogs 0 30.03.2018 17:11
daxrunbase: Fix Table and Field ID synchronization conflicts in AX Blog bot DAX Blogs 0 05.08.2017 19:30
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Microsoft Dynamics CRM Team Blog: How to Import attachments programmatically Blog bot Dynamics CRM: Blogs 0 07.08.2012 00:13
Часовой пояс GMT +3, время: 06:27.
