Старый 24.05.2021, 05:12   #1
Kashperuk Ivan: [Development tutorial] Thoughts on test automation + more sample tests using ATL
Источник: http://kashperuk.blogspot.com/2021/0...s-on-test.html
I recently had an interesting discussion around testing and specifically Microsoft testing efforts and frameworks, namely, ATL. If you are not familiar with this framework - you've been living under a rock. Get out from under there and go read some articles about it, like the one belowhttps://kashperuk.blogspot.com/2019/05/development-tutorial-sample-test-tips.htmlThe discussion revolved around
Kashperuk Ivan: [Development tutorial] Sample test + tips for using ATL (Acceptance Test Library) to implement tests in Warehouse management Blog bot DAX Blogs 0 21.05.2019 02:53
Kashperuk Ivan: Development tutorial: SysExtension framework with SysExtensionIAttribute and an Instantiation strategy Blog bot DAX Blogs 0 01.04.2017 02:17
Kashperuk Ivan: Development tutorial: SysExtension framework in factory methods where the constructor requires one or more arguments Blog bot DAX Blogs 4 19.03.2017 23:56
Kashperuk Ivan: Development tutorial: Extensible base enumerations in Microsoft Dynamics AX 7 Blog bot DAX Blogs 0 27.09.2016 00:19
NAV Team: Test Automation and Test Data Blog bot Dynamics CRM: Blogs 0 01.10.2010 12:56
Часовой пояс GMT +3, время: 05:14.
