Старый 11.08.2020, 23:12   #1
msdynamicsworld: Dynamics 365 Finance: Emailing payment advice using batch job and print management configuration
Источник: https://msdynamicsworld.com/story/dy...int-management
Dynamics 365 Finance can be configured to automatically send payment advice to vendors using a batch job. And while earlier versions offered payment advice, it had to be either printed to the screen or the vendor email addresses had to be entered manually. While it did the job, it was often a little tedious for customers who would like to automate it.
With the 2019 December release, Microsoft added the ability to send payment advice via configuration based on print management – yes, you read that right--and use a batch job based on whatever conditions the user wants.
Below is the feature you need to enable in order to proceed with this setup.
Once the feature is enabled, under Accounts Payable -> Print management the below configuration should be enabled/created as a prerequisite.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Часовой пояс GMT +3, время: 05:17.
