Старый 16.07.2020, 13:11   #1
ariste.info: Add a Menu Item to a SysOperation dialog
Источник: https://ariste.info/en/2020/07/add-m...ration-dialog/
A short one! Some time ago I explained how to add a multi selection lookup to a SysOperation dialog and in this post I’ll explain how to add a Menu Item as a Function button to the SysOperation dialog. Before the SysOperation Framework was introduced in AX2012, we used the RunBase Framework, and maybe doing … Continue reading Add a Menu Item to a SysOperation dialog →
La entrada Add a Menu Item to a SysOperation dialog se publicó primero en ariste.info.
ariste.info: Messaging API: add actions to the message bar Blog bot DAX Blogs 0 08.04.2020 09:13
stoneridgesoftware: Batch Processing in Dynamics AX 2012 Using SysOperation Framework Blog bot DAX Blogs 0 28.03.2017 00:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Axapta Lessons: Add menu options to the Add-Ins submenu Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 16:20.
