Старый 13.06.2020, 05:30   #1
General journals log update bugs
Источник: http://alexvoy.blogspot.com/2020/06/...date-bugs.html
I found a couple questionable things in General journal log updating.
First, Log field limit of 255 characters. It is evidently not enough for relatively long information to be stored for eventual analysis.
Second, the way to update journal logs by copying lines from Infolog afterwards.
Anyway the standard methods meant to shorten the log content do not work properly. Let's see why.
And the method to find a voucher number can speak one language only.
So, we get a poorly built journal log.
It can be fixed by two extensions.
First, let's gather all lines in a set so that they would be present once only.
/// Extension of LedgerJournalCheckPost to fix a bug
[ExtensionOf(classStr(LedgerJournalCheckPost))]
final class CDPLedgerJournalCheckPost_Extension
/// Updates the infolog for the given transaction.
/// The transaction.
public void updateTransInfoLog(LedgerJournalTrans _ledgerJournalTrans)
this.cdpUpdateTransInfoLog(_ledgerJournalTrans);
// transLogPoint is already moved forward; therefore the next call will do no change to the log
next updateTransInfoLog(_ledgerJournalTrans);
private void cdpUpdateTransInfoLog(LedgerJournalTrans _ledgerJournalTrans)
#Define.UserTab('\t')
Log logTxt;
Integer x = transLogPoint;
Integer y = infolog.num(0);
str currentLine;
str strLine;
Voucher voucher;
List list;
ListEnumerator listEnumerator;
Set setAllLines = new Set(Types::String);
Log tableLogTxt;
#ISOCountryRegionCodes
boolean countryRegion_RU = SysCountryRegionCode::isLegalEntityInCountryRegion([#isoRU]);
if (postingResults)
postingResults.parmLedgerPostingMessageLog(ledgerPostingMessageCollection);
while (x < y)
x++;
// parse all the lines if there are some prefixes
currentLine = infolog.text(x);
list = strSplit(currentLine, #UserTab);
listEnumerator = list.getEnumerator();
while (listEnumerator.moveNext())
currentLine = listEnumerator.current();
if(setAllLines.in(currentLine))
continue;
setAllLines.add(currentLine);
if (countryRegion_RU)
logTxt = currentLine + '\r\n';
tableLogTxt += logTxt;
else
logTxt += currentLine + '\r\n';
if (logTxt && postingResults != null)
if (_ledgerJournalTrans.Voucher == '')
voucher = LedgerJournalCheckPostResults::getVoucherFromLogText(currentLine);
if (voucher == '')
// continue because calling the LedgerJournalCheckPostResults.updateErrorLog
// method with a blank voucher has terrible performance and will not change the results
continue;
else
voucher = _ledgerJournalTrans.Voucher;
postingResults.updateErrorLog(voucher, logTxt);
logTxt = tableLogTxt;
if (logTxt)
tableErrorLog += logTxt;
transLogPoint = y;
Second, teach the voucher searching method to speak any language and do not return rubbish instead of a real voucher number.
/// Extension of LedgerJournalCheckPostResults to fix a bug
[ExtensionOf(classStr(LedgerJournalCheckPostResults))]
final class CDPLedgerJournalCheckPostResults_Extension
/// See the description for the standard method
/// log text
/// Voucher text
public static Voucher getVoucherFromLogText(Log _logText)
// this standard function does not works correctly
next getVoucherFromLogText(_logText);
return LedgerJournalCheckPostResults::CDPGetVoucherFromLogText(_logText);
/// Finds voucher numbers as it should be in all languages
/// Log text
/// Voucher text
private static Voucher cdpGetVoucherFromLogText(Log _logText)
List list;
Voucher voucher;
str strLine;
const str voucherText = '@GeneralLedger:Voucher';
int voucherLen = strLen(voucherText);
list = strSplit(_logText, ',');
listEnumerator= list.getEnumerator();
strLine = listEnumerator.current();
if (strContains(strLine, voucherText))
// delete the word VOUCHER in any language as well as all the spaces around
voucher = strLRTrim(strDel(strLine, 1, voucherLen));
break;
return voucher;
Now it looks much better and contains condensed information.
For storing more information, a new memo field can be a solution.
Hope, Microsoft will eventually come up with an optimized approach.
Good logging!
Часовой пояс GMT +3, время: 00:22.
