Старый 06.12.2019, 03:27   #1
Navigate Into Success: Control Add-ins Supercharged: Debugging with source maps
Источник: http://vjeko.com/control-add-ins-sup...h-source-maps/
So far I’ve shown how to configure gulp to help you with some basic JavaScript development tasks, such as bundling and minifying, and how to automate builds on every source file change. Let’s now take it to an entirely new level: debugging.
If you ever tried to debug your control add-in source code using Visual Studio Code, you might have realized two things: first, that it’s actually pretty simple to do; and second, that it’s not the kind of debugging that you want.
Let’s see why that is.
First, using VS Code with a browser such as Chrome, Edge (especially “Canary”, mmmm) or Firefox is easy. There are debugging extensions built for that purpose that allow you to either launch a browser with VS Code attached as a debugger, or to attach VS Code to a running instance of a browser (some browser configuration needed beforehand). However, when you use VS Code as a debugger like this, it’s hardly more than a glorified browser built-in developer tool – the only benefit of using VS Code is that, well, you are in VS Code, rather than inside the browser. However, you are not really debugging your source files – you are debugging scripts currently loaded in the browser. You can’t set debug breakpoints in your source files – you can only set them in copies of files that are loaded by the browser. If you catch a bug (kind of a point with a debugger) you can’t stop the process and immediately change the line where the bug is, but you have to first locate the matching source script, and then the offending line, and then fix it there. Not exactly a fun pastime.
And that’s annoying enough if you have a single script to work with, but if you have several scripts, bundled together, then minified, well, good luck with that. Debugging minified code is as close as you can get to inquisition-level torture in this century.
So, let’s fix this mess, and let’s enable debugging as it should be – let’s enable debugging of actual source files with full breakpoint integration and all.
That’s what my next branch is about. In it, I introduce source maps and how you can use gulp to build them. And then I explain how you can configure your VS Code to debug your source files.
So, head over to https://github.com/vjekob/supercharg.../06-gulp-debug and check out some pretty cool stuff.
Read this post at its original location at http://vjeko.com/control-add-ins-sup...h-source-maps/, or visit the original blog at http://vjeko.com. 5e33c5f6cb90c441bd1f23d5b9eeca34The post Control Add-ins Supercharged: Debugging with source maps appeared first on Vjeko.com.
Navigate Into Success: Control Add-ins Supercharged: Teaching gulp some useful tricks Blog bot NAV: Blogs 0 03.12.2019 06:21
Navigate Into Success: Control Add-ins Supercharged: Hello, gulp! Blog bot NAV: Blogs 0 29.11.2019 17:11
Navigate Into Success: Control Add-ins Supercharged – Separating concerns Blog bot NAV: Blogs 0 27.11.2019 23:12
Navigate Into Success: Control Add-ins Supercharged – Kicking off Blog bot NAV: Blogs 0 27.11.2019 06:24
Navigate Into Success: Deploying control add-ins during development in NAV 2016 Blog bot Dynamics CRM: Blogs 0 13.11.2015 10:00
Часовой пояс GMT +3, время: 01:17.
