Старый 15.08.2019, 20:12   #1
stoneridgesoftware: Take Advantage of Temp Vouchers in Dynamics 365 Finance and Operations
Источник: https://stoneridgesoftware.com/advan...ce-operations/
Is there a temp voucher in your future? While by no means a new feature, it is one that I use regularly.  Let’s talk about using temporary voucher numbers in Dynamics 365 for Finance and Operations!
As an entry is created in a journal, a voucher number is assigned according to the designated number sequence for that journal. Sometimes it is advantageous to use a temporary value when vouchering a transaction to avoid a collision in numbering formats.
Microsoft Dynamics 365 for Finance and Operations supports a configuration that generates a temporary voucher number that is updated at the time of posting with the designated number sequence. This setting may reduce the likelihood that the following error message is encountered: “Voucher XXX is already used as of date XXX.”
To take advantage of temp vouchers, follow these steps:
1. Navigate to General ledger/Ledger setup/General ledger parameters
2. Open the Number sequences tab
3. Locate the Reference section for Temporary voucher number
  •  Make sure that there is a number sequence assigned for this reference
  •  Validate that the assigned number sequence is large enough to support anticipated transaction volumes
4. Navigate to General ledger/Journal setup/Journal names
5. Locate the journal to be updated OR if creating a new journal
  • In the Voucher number section, the setting for “Number allocation at posting” set to YES as shown in Figure 2.
Following our setup for Customer payment journal as an example:
Testing should indicate the voucher values as defined from series Gene_25 prior to posting the journal and the voucher values as defined from series AR_Pay after posting the journal.
As always, please test any changes to the configuration in an environment designated for testing before implementing in a live production environment.
If you have questions or need any assistance, please reach out to the team at Stoneridge Software.
stoneridgesoftware: How ‘One Version’ Affects Dynamics 365 Finance and Operations Users Blog bot DAX Blogs 0 10.05.2019 19:16
stoneridgesoftware: The Four Steps to Upgrade from Dynamics AX to Dynamics 365 Finance and Operations Blog bot DAX Blogs 0 12.02.2019 19:11
powerobjects: How to Integrate Power BI with Dynamics 365 for Finance and Operations Blog bot Dynamics CRM: Blogs 0 26.06.2018 01:23
stoneridgesoftware: Overview of Product Compliance Features in Dynamics 365 for Finance & Operations Blog bot DAX Blogs 0 03.05.2018 12:11
Часовой пояс GMT +3, время: 06:35.
