Старый 30.01.2019, 14:11   #1
dynamicsaxinsight: D365: Send email in X++ using email templates
Источник: https://dynamicsaxinsight.wordpress....ail-templates/
Product:
Dynamics 365 for Finance and Operations
Purpose:
The purpose of this document is to demonstrate how we can send emails in X++ using built-in email templates. For demonstration purposes we’ll be using standard email template CnfmOrder. This email template is used to send email to customer when a sales order is confirmed.
Business requirement:
Automate sending email to customer’s contact when a sales order is confirmed.
Prerequisites:
Email parameters must be configured.
Development:
You can find built-in email templates in the system under:
Organization administration > Setup > Email templates
Note that we have keyed in the sender email field as it will be used in the code as the “Sender”.
You can use the following code to automatically send email using X++. The given code also handles inserting placeholder values in the email template. It uses salesId variable which is a global class member and is provided by the caller class.
public void generateEmail(){ // Tokens for email template replacement #define.SalesIdToken('salesid') #define.CustNameToken('customername') #define.DeliveryAddress('deliveryaddress') #define.CustomerAddress('customeraddress') #define.ShipDate('shipdate') #define.ModeOfDelivery('modeofdelivery') #define.Charges('charges') #define.Discount('discount') #define.Tax('tax') #define.Total('total') #define.LineProductName('lineproductname') #define.LineProductDesc('lineproductdescription') #define.LinePrice('lineprice') #define.LineQuantity('linequantity') #define.LineNetAmount('linenetamount') SalesTable salesTable; SalesLine salesLine; CustTable custTable; ContactPerson contactPerson; SalesTotals salesTotals; SysEmailId emailId; Map templateTokens; str emailSenderName; str emailSenderAddr; str emailSubject; str emailBody; str emailToAddress; salesTable = SalesTable::find(salesId); salesLine = SalesLine::find(salesTable.SalesId); custTable = CustTable::find(salesTable.CustAccount); contactPerson = ContactPerson::find(salesTable.SixCustContactPersonId); salesTotals = SalesTotals::construct(salesTable); emailToAddress = contactPerson.email(); emailId = salesTable.SixSysEmailId; templateTokens = new Map(Types::String, Types::String); templateTokens.insert(#SalesIdToken, salesTable.SalesId); templateTokens.insert(#CustNameToken, custTable.name()); templateTokens.insert(#DeliveryAddress, salesTable.deliveryAddress().Address); templateTokens.insert(#CustomerAddress, custTable.address()); templateTokens.insert(#ShipDate, strFmt("%1", salesTable.ShippingDateRequested)); templateTokens.insert(#ModeOfDelivery, strFmt("%1", salesTable.DlvMode)); templateTokens.insert(#Charges, strFmt("", salesTotals.totalMarkup())); templateTokens.insert(#Discount, strFmt("", salesTotals.totalEndDisc())); templateTokens.insert(#Tax, strFmt("", salesTotals.totalTaxAmount())); templateTokens.insert(#Total, strFmt("", salesTotals.totalAmount())); templateTokens.insert(#LineProductName, salesLine.itemName()); templateTokens.insert(#LineProductDesc, salesLine.itemLineDisc()); templateTokens.insert(#LinePrice, strFmt("%1", salesLine.SalesPrice)); templateTokens.insert(#LineQuantity, strFmt("%1", salesLine.SalesQty)); templateTokens.insert(#LineNetAmount, strFmt("%1", salesLine.LineAmount)); if (emailId) { [emailSubject, emailBody, emailSenderAddr, emailSenderName] = SixCustVendEmailController::getEmailTemplate(emailId, custTable.languageId()); } var messageBuilder = new SysMailerMessageBuilder(); messageBuilder.addTo(emailToAddress) .setSubject(emailSubject) .setBody(SysEmailMessage::stringExpand( emailBody, SysEmailTable::htmlEncodeParameters(templateTokens))); if (emailSenderAddr) { messageBuilder.setFrom(emailSenderAddr, emailSenderName); SysMailerFactory::getNonInteractiveMailer().sendNonInteractive(messageBuilder.getMessage()); }}The generateEmail() method calls the following method to get the email template:
protected static container getEmailTemplate(SysEmailId _emailId, LanguageId _languageId){ var messageTable = SysEmailMessageTable::find(_emailId, _languageId); var emailTable = SysEmailTable::find(_emailId); if (!messageTable && emailTable) { // Try to find the email message using the default language from the email parameters messageTable = SysEmailMessageTable::find(_emailId, emailTable.DefaultLanguage); } if (messageTable) { return [messageTable.Subject, messageTable.Mail, emailTable.SenderAddr, emailTable.SenderName]; } else { warning("@SYS135886"); // Let the user know we didn't find a template return ['', '', emailTable.SenderAddr, emailTable.SenderName]; }}Once triggered, the code sends out the email through the configured SMTP server and can be found in the inbox:
stoneridgesoftware: Customizing Report Layouts and Email Templates in Dynamics 365 Business Central Blog bot DAX Blogs 0 22.03.2018 03:39
dynamicsaxinsight: AX7/D365/Operations: Create Details Master pattern form Blog bot DAX Blogs 0 14.09.2017 13:11
stoneridgesoftware: Email Alerts on Power BI Dashboards with Microsoft Flow – Better Together Blog bot DAX Blogs 0 19.01.2017 20:11
Leon's CRM Musings: Using Email Templates to Communicate With External Parties Blog bot Dynamics CRM: Blogs 0 25.09.2014 21:12
Microsoft Dynamics CRM Team Blog: Adding attachments to Templates and Bulk email Blog bot Dynamics CRM: Blogs 1 29.12.2010 15:43
Часовой пояс GMT +3, время: 00:53.
