Старый 03.01.2019, 18:13   #1
axaptacorner: Error while restarting AX2012 service
Источник: http://axaptacorner.blogspot.com/201...2-service.html
Issue: The database Servername\ModelDatabase is not recognised as a model store
Below error occurred while restarting AX2012 service after database restore:
Event log error:
Object Server 01:The database Servername\ModelDatabase is not recognized as a model store
Object Server 01: Fatal SQL condition during login. Error message: "[Microsoft][SQL Server Native Client 10.0][SQL Server]Login failed for user “User name”
Solution:
1. This issue happen when service account do not have access on the database from where we took backup. So simply AOS component can be uninstalled and installed again which will fix the issue.
2. After database refresh add AX service account in database security section and provide proper permission which will fix the issue.
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
AIF: Microsoft Dynamics AX Services and Windows Azure Service Bus Blog bot DAX Blogs 0 24.07.2013 03:13
Freddys: Multiple Service Tiers Blog bot Dynamics CRM: Blogs 0 30.10.2008 01:59
Часовой пояс GMT +3, время: 01:03.
