Старый 03.12.2018, 18:11   #1
mfp: WhsWorkExecuteDisplay replacement
Источник: https://blogs.msdn.microsoft.com/mfp...y-replacement/
If you ever tried to implement a process on the mobile device used primarily in warehouse, you'll have come across a class named WhsWorkExecuteDisplay. If you are not so fortunate, consider looking at the code. There are many software craftmanship lessons hidden here. This class and its subclasses are not as extensible as we need...
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
axStart: Replacement key in AX 2012 Blog bot DAX Blogs 0 15.05.2013 22:13
mfp: Dynamics AX EMEA Technical Conference 2011 Blog bot DAX Blogs 0 21.09.2011 18:11
mfp: AX models - Part 4 - Working with models inside MorphX Blog bot DAX Blogs 4 26.11.2009 16:55
mfp: Sneak preview - Code Upgrade Enhancements Blog bot DAX Blogs 0 02.03.2007 20:46
Часовой пояс GMT +3, время: 18:30.
