Старый 01.11.2018, 03:14   #1
yetanotherdynamicsaxblog: Upgrade from 7.x to 8.+ series | Post 5 | Upgrade Sandbox and finally Production
Источник: http://yetanotherdynamicsaxblog.blog...es-post-5.html
Introduction
In these series of posts. I will try to run you through the process of how you can complete the upgrade from 7.x to 8.+ of Dynamics 365 for Finance and Operations.
Quick navigation:
Upgrade from 7.x to 8.+ series | Post 1 | Start in LCS
Upgrade from 7.x to 8.+ series | Post 2 | Deploy Dev and Grab source DB
Upgrade from 7.x to 8.+ series | Post 3 | Validate Code and Data in Dev
Upgrade from 7.x to 8.+ series | Post 4 | Setup a new Build
Upgrade from 7.x to 8.+ series | Post 4 | Upgrade Sandbox and finally Production (you are here)
Prepare a sandbox upgrade for validation
Before you can go ahead and request an upgrade of Production, you will want to do a pre-production validation in the sandbox environment. You may read the details here:
https://docs.microsoft.com/en-us/dyn...ox-environment
The actual steps are well documented here:
Before you start this process, you will want to make sure you have the following uploaded to LCS Asset Library:
  • Upgraded application (Software Deployable Package), downloaded from the successfull build.
  • Backup of source database as bacpac. If you need a fresh backup from Production, this is the time to get one. Use the scripts from previous posts to extract a bacpac, if necessary.
If you've followed the previous posts. you should by now have this ready.
The next steps are simply:
  1. Redeploy sandbox with target version. Make sure to select the upgraded application package. If you don't, you will have to install it afterwards, before you continue to the next step.
  2. Import the bacpac from the source. Here you can use the tooling in LCS.
  3. Run the DatabaseUpgrade-81 package.
Then you can let the users start hammering on the system to potentially discover everything is flawless (knock on wood).
Finally Production
When you are ready to do the actual upgrade of Production, the flow is a lot simpler, and very well outlined on the official documentation. So I will simple refer to docs here.
Good luck!
survivingcrm: From AppSource to Solutions to Dynamics 365 Apps Blog bot Dynamics CRM: Blogs 0 14.01.2018 19:16
waldo: NAV Upgrade: Import and Compile crashes when NST is running Blog bot NAV: Blogs 0 16.06.2016 10:11
Часовой пояс GMT +3, время: 09:57.
