Старый 11.10.2018, 15:11   #1
crmtipoftheday: Tip #1177: Use the CDS connector when you go with the flow
Источник: https://crmtipoftheday.com/1177/use-...with-the-flow/
MVP Elaiza Benitez gave me some very helpful advice when it comes to Microsoft Flow:
If you want to filter Dynamics 365 records to only records that you create in your flow, you should use the CDS when a record is created (preview) trigger, not the Dynamics 365 trigger. If you use the CDS trigger, you can set the scope to “User.” This way the Flow will only execute if you create the record. This makes flow more consistent with how Dynamics 365 Workflow works, and vastly simplifies Tip 835.
For more details on how to use scope in your flow, check out episode 1 of Elaiza’s fantastic vlog series WTF.
crmtipoftheday: Tip #1172: Make your CDS environments visible with a touch of Flow Blog bot Dynamics CRM: Blogs 0 12.09.2018 17:11
crmtipoftheday: Tip #1124: Flow Approvals May Be Exactly What You Need Blog bot Dynamics CRM: Blogs 0 25.06.2018 12:11
crmtipoftheday: Tip #1094: It is Time to Go with the Flow Blog bot Dynamics CRM: Blogs 0 27.03.2018 09:11
crmtipoftheday: Tip #1007: What is the Common Data Service (CDS) today? Blog bot Dynamics CRM: Blogs 0 23.10.2017 19:12
Часовой пояс GMT +3, время: 21:52.
