Старый 06.08.2018, 11:11   #1
d365technext: Performance Tool in D365FO
Источник: http://d365technext.blogspot.com/201...in-d365fo.html
Today, I found standard feature of performance optimization in Dynamics 365 For Finance and Operations ....
Microsoft called this feature as Performance tool
You can find the navigation of this tool as below...
You will find lots of option here to optimization, Over internet I didn't find any documentation of this feature. So I am sharing some items i have explored.
There is Text box where we can Enter of the number of records on which we want to check performance using this tool.
Microsoft Divide this Feature in 4 Category
  1. Data Manipulation
  2. Query
  3. Temp DB & In Memory
  4. Cache
Data Manipulation
In this MS Checking the performance of
Insert
Update
Record Insert List
Insert Record set
update record set
delete from
Query
In this section testing will perform on the below points
  1. Large Buffer read
  2. Cluster Index
  3. Unique index with cache hit
  4. Unique index without cache hit
  5. Non-Unique Index
Temp DB & In Memory
In this section we can check the performance on Temp DB and In Memory....
Cache
The same number of records will store in cache ...
Important
Note that running for 1,000 records will take approximately 1 minute, so be careful using larger numbers not to run into form timeouts. The max record count is 100,000.
dennis365foroperations: Performance test tool in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 25 23.07.2025 16:29
emeadaxsupport: AX Performance - What information and data to collect when you want to open a support case Blog bot DAX Blogs 0 29.09.2015 15:11
emeadaxsupport: Managing general performance issues in Microsoft Dynamics AX Blog bot DAX Blogs 0 12.09.2014 12:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
Arijit Basu: SQL Database Performance Monitoring- Nice Tool Blog bot DAX Blogs 0 22.10.2009 01:09
Часовой пояс GMT +3, время: 03:16.
