Старый 25.05.2018, 11:11   #1
Simple form for Financial dimension value set lookup
Источник: http://alexvoy.blogspot.com/2018/05/...dimension.html
Simple form for Financial dimension lookup.
On any form a consultant can add Fin dim field, which is actually just a rec id, then click on it to see the real value set. (Added FormRef to DimensionAttributeValueSet table.)
If opened as a separate window, the form allows to lookup any fin dim value.
Download AX 2012 XPO file.
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 23:00.
