Старый 14.03.2018, 16:11   #1
dynamicsnavax: Approve Workflow via email using template placeholders #Dyn365FO
Источник: http://dynamicsnavax.blogspot.com/20...ail-using.html
Dynamics 365 for Finance and Operations has placeholders which can be inserted into the instructions. Normally you would want this to show up in the email that is sent. One of the most useful ones is the URL link to the exact record that you are approving.
In the workflow configurations use the placeholder and build up your message. Towards the end it has workflow specific ones. The URL token is %Workflow.Link to web%.
For the technical people the token is replaced in this class WorkflowDocumentField.
This is what I inserted into my email template.
subject: %subject%
message: %message%
company: %company%
for: %for%
Should look like this.
The final result looks like this.
If you debug these are the place holders that are put together.
d365o, workflow
vanvugt: How-to: Create a Workflow Template Blog bot NAV: Blogs 0 15.05.2016 18:12
Van Vugt: How-to: Create a Workflow Template Blog bot Dynamics CRM: Blogs 0 27.12.2015 17:00
Crm 3.0: custom workflow create email from template wb Dynamics CRM: Разработка 7 04.03.2010 00:02
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 23:25.
