Старый 24.01.2018, 16:11   #1
DynamicsAxSCM: Negative inventory in inventory accounting
Источник: https://blogs.msdn.microsoft.com/dyn...ry-accounting/
Allowing physical negative inventory may have undesirable consequences in inventory accounting, especially if the inventory costing principle is Actual and the valuation method is either FIFO or Weighted average. Most of the issues that are related to physical negative inventory can be mitigated by using the correct configuration and maintenance of data. Example: Why is...
DynamicsAxSCM: Inventory on-hand movements/transfers using the mobile device menus Blog bot DAX Blogs 0 14.01.2016 15:11
axmfg: More about (dynamic) negative days Blog bot DAX Blogs 0 19.02.2015 23:16
DynamicsAxSCM: Accounting for Purchase charge and Stock variation Blog bot DAX Blogs 0 16.12.2014 12:11
DynamicsAxSCM: WMS in Microsoft Dynamics AX 2009. Outbound Process Setup Blog bot DAX Blogs 0 27.04.2009 03:23
Часовой пояс GMT +3, время: 19:08.
