Старый 31.12.2017, 16:24   #1
erconsult: On provisions, accruals and deferrals
Источник: http://erconsult.eu/blog/provisions-accruals-deferrals/
It is holiday season, time to close the accounting year, accrue prepaid expenses in your books and build provisions for anticipated losses, reducing your corporate tax base and saving money.
If an AP invoice for goods or services has been received in or before the year-end but refers to the next year or financial period, this prepaid expense represents an asset in the balance and should be removed from the current P&L:
Debit “7x Office rental” Credit “1x Cash”.
Debit “2x Prepaid expense” Credit “7x Office rental”.
If an invoice for anticipated expenditures or contractual obligations has not been received yet, but relate to the current accounting year, this provision is represented by a liability in the balance:
Debit “7x Audit” Credit “3x Provision”.
In “Dynamics 365 for Finance and Operations (EE)” there are in essence 3 methods to represent these accruals, each with its own benefits and shortcomings: Reversing entry, Accrual schemes and Deferrals.
Reversing entry
The Reversing entry feature is good for provisions if they are not allocated over time / accounting months, but built on the 31th of December and dissolved immediately on the 1st of January.
In the basic General ledger > Journal entries > General journals, you just tick the Reversing entry checkbox and enter the Reversing date. On posting the journal, the system automatically adds a second journal line where it swaps the debit with credit:
This simple feature fulfils the purpose of reducing the tax load in the financial year, but 1) it is unable to allocate the expenditure over multiple periods, and 2) it books the second voucher in the future period. It is a good accounting practice to only keep one accounting period open, which is going to manifest itself in the error message “The financial period is closed for module Ledger on the date 01.01.2018”.
Accrual schemes
The Accrual schemes are better in the sense that they are capable to allocate prepaid expenses over time, but share many disadvantages with the Reversing entry:
1) accrual schemes are only available in General Ledger journals and cannot be applied to an AP invoice;
2) they book in future [closed] financial periods, and these transactions are final and cannot be changed;
3) an accrual scheme cannot reverse the provision entry at the end of the designated period.
<div>The feature was made in an assumption that the expense to accrue is posted/debited in the same voucher, which in a large organization may defy the principle of segregation of duties embodied by different forms used to enter the invoice (AP Pending invoice form) and to accrue them (GL journal).
In the below example an General ledger > Journal setup > Accrual scheme
is triggered in the GL journal line by clicking Functions > Ledger accruals. On the screenshot below the accrual was applied to a contra-intuitive second line in the GL journal line to trick the system into the desired Dr Expense Cr Prepaid posting (use the Transactions button in the Ledger accruals dialog box to preview the result):
The resulting GL voucher resembles a battlefield, but can be reduced to the following: 1/3 of the expense was recognized, 2/3 of the prepaid expense remained in the balance:
</p>Deferrals
Since the early versions of Dynamics (namely, Axapta 3.0) there has been a sub-module called Deferrals in the Russian localized version: https://technet.microsoft.com/en-us/.../jj678354.aspx. It is free of the Accrual scheme handicaps, because it keeps the evidence of prepaid expenses and provisions in a separate ledger and does not impose GL transactions in future periods. It resembles the Fixed Assets module and supports 3 types of operations (transaction types):
  • The co-called “Receipt”, i.e. “zeroing out” the expense amount in the AP invoice period
  • Writing off”, i.e. recurring prorated transactions allocated over a number of accounting periods and posted on the 1st of every period
  • The so-called “Retirement” or Disposal, i.e. dissolving a provision
Since AX2012 this sub-module has only been available in a legal entity with the primary address in Russia. In the latest releases of Dynamics “Dynamics 365 for Finance and Operations (EE)” it became possible to extend all RDeferrals* application elements, add country codes and ‘jailbreak’ the desired functions.
To implement the module in Switzerland, I infused the module it with a multi-currency capability to store the currency code and the exchange rate in the Deferrals table, and populate the fields Currency, Exchange rate and the Secondary exchange rate in the resulting GL journal lines. Moreover, the Main account in the deferrals model table was customized to uptake the individual expense account from the AP invoice line and simplify the setup compared to the Accrual schemes: there should be no need to create an own Scheme for all 50 expense accounts in question. Finally, to increase productivity of the accountant the AP Pending invoice was enhanced to create Deferrals records automatically for every line (or expense account in the distribution).
The process begins with recording a prepaid expense in the General Ledger > Common > Deferrals list.
A new Deferrals [model] record becomes the status Scheduled i.e. awaiting the “Receipt” transaction. The pending Receipt operations intended to credit and neutralize the expense in the current accounting period are proposed by the system in the General ledger > Journal entries > Deferrals journal:
The monthly allocation is performed in the similar manner where the user creates a new Deferrals journal and uses the button Group operations > Writing off in the Lines. This generates outstanding transaction proposals for all accrual records in the status ‘In process’ up to the Transaction date specified:
N.B: In standard Dynamics due to some wicked design decision, the horizon for the transactions is the end of the month preceding the Transaction date. I.e. a Transaction date = 31.12.2017 brings transactions up to the 1st of November. It was necessary to customize this.
<div>As a result, by the end of December 1/3 of the expense is recognized, and 2/3 of the prepaid expense remains in the balance:
</p>The post On provisions, accruals and deferrals appeared first on ER-Consult.
accrual
Часовой пояс GMT +3, время: 13:46.
