Старый 28.11.2017, 18:11   #1
Art Of Creation: CombineXPO: Length cannot be less than zero
Источник: http://www.artofcreation.be/2017/11/...ess-than-zero/
We are moving from AX 2012 FP to AX 2012 R3 and our daily build was failing with the following error:
We have traced the problem to the xpo files in version control that contain the (shared) projects. When these are added to the XPO, you get the error above.
There is a blogpost here that explains the problem.
So apparently, when moving from AX 2012 FP to AX 2012 R2 or R3, Microsoft has changed the file encoding of the xpo files for projects from UCS-2 Little Endian to UTF-8. CombineXPO has problems with this so it throws an error.
I did not make changes to CombineXPO, instead to solve this problem, I have converted all projects in my local repository to UTF-8 using a tool called UTFCast . Just make sure you have the Write BOM parameter checked. Then it’s just a matter of checking them in using Visual Studio. After that the build was succesful.
Art Of Creation: SSRS: rsErrorInOnInit error Blog bot DAX Blogs 0 13.09.2017 17:11
Art Of Creation: Workflow: An unexpected error has occurred while opening the workflow. See the event log on the AOS and contact your system administrator to resolve the issue. Blog bot DAX Blogs 0 13.09.2017 17:11
Art Of Creation: Workflow: Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics. Blog bot DAX Blogs 0 13.09.2017 17:11
Art Of Creation: What you should know about database logging: functional impact Blog bot DAX Blogs 0 13.09.2017 17:11
bojensen: Art Of Creation – Dynamics AX Blog » How to print any file in Dynamics AX Blog bot DAX Blogs 0 15.07.2015 18:11
Часовой пояс GMT +3, время: 11:23.
