Старый 04.09.2017, 15:11   #1
k3technical: Running an Electronic Report from a menu item
Источник: http://www.k3technical.com/running-a...m-a-menu-item/
Earlier I discussed how to create a new type of Electronic Report in Dynamics 365 for Operations (AX7), which can be viewed here,  Creating new Electronic Report. In this post, I want to look at how to modify the application … Continue reading →
The post Running an Electronic Report from a menu item appeared first on K3 Technical Blog.
ger
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Kashperuk Ivan: Running a class from AOT or "How to assign a class to an action menu item?" Blog bot DAX Blogs 0 22.10.2009 20:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 09:46.
