Старый 28.04.2017, 20:11   #1
emeadaxsupport: Source document or Accounting distribution?
Источник: https://blogs.msdn.microsoft.com/axs...-distribution/
This blog will explain the purpose of the General Ledger Parameter ‘Values used for summary account’ You can choose 2 values here, either ‘Source document’ or ‘Accounting distribution’ The purpose of this parameter very shortly is that it governs which dimension should be used on a summary account. If you select ‘Source document’, the dimension... Read more
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
ax_gfm_framework_team: Integrating a Source Document with Budget Control Blog bot DAX Blogs 0 18.07.2012 00:11
ax_gfm_framework_team: Step 5: Add code to distribute and journalize source document amounts Blog bot DAX Blogs 0 08.05.2012 04:13
ax_gfm_framework_team: Step 3: Perform initial wiring to Source Document Framework – document classes Blog bot DAX Blogs 0 01.05.2012 18:11
Часовой пояс GMT +3, время: 03:36.
