Старый 12.04.2017, 02:30   #1
organicax: Materials in process report
Источник: https://organicax.com/2017/04/11/mat...rocess-report/
When you are managing production and looking at inventory costs and work in process you might need to run a report to investigate the material that is WIP. There is a report that might be handy which is the materials in process report. It lists what materials have been consumed on a production order where the production order hasn’t been ended.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
NAV Team: Using SQL Server Extended Events to produce a Blocked Process Report Blog bot Dynamics CRM: Blogs 0 16.01.2015 20:11
Microsoft Dynamics CRM Team Blog: Using the Business Process Flow Designer Blog bot Dynamics CRM: Blogs 0 24.10.2013 05:13
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Часовой пояс GMT +3, время: 11:59.
