Старый 04.01.2017, 20:13   #1
emeadaxsupport: DIXF – AX 2012 R3 – KB3216243 – Assume service is on active SQL Server node
Источник: https://blogs.msdn.microsoft.com/axs...l-server-node/
We recently released a DIXF Application Hotfix for AX 2012 R3 that you may want to take a look at if you are running a Clustered configuration / AlwaysOn configuration: The changes in the hotfix introduce a new option of “Assume service is on active SQL Server node” on the “Data import/export framework parameters” form.... Read more
dynamicsaxse: Microsoft Edge ,Chrome and SQL Server 2014 SP2 are now supported with AX 2012 R3 and AX 2012 R2 Blog bot DAX Blogs 0 22.11.2016 13:11
emeadaxsupport: Installing the AX 2012 R3 Async Server to a Clustered SQL Server Environment Blog bot DAX Blogs 0 05.12.2014 19:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
Часовой пояс GMT +3, время: 04:32.
