Старый 15.11.2016, 03:19   #1
organicax: Recording screen shots with the task recorder
Источник: https://organicax.com/2016/11/14/rec...task-recorder/
The task recorder concept has been in AX for a long time and has had a few variations. In D365 the task recorder is still there that you can use to create task guides for users. However if you want to record screen shots then you will have to use Google Chrome and enable an extension.
Here is a quick overview
D365FO 1611 – Update3 (7.0.4307.16141)
You can find the download used in the recording here
https://github.com/Microsoft/FMLab
The main help topic for the task recorder is located here
Task Recorder in Microsoft Dynamics 365 for Operations</p>
Cheers
Lachlan
Filed under: User tips
stoneridgesoftware: Working with Task Recorder and Task Guide in New Microsoft Dynamics AX Blog bot DAX Blogs 0 27.05.2016 00:16
Microsoft Dynamics CRM Team Blog: Creating and customizing task flows Blog bot Dynamics CRM: Blogs 0 11.12.2015 04:14
atinkerersnotebook: Use Your Own Personalized Template When Creating Documents From The Task Recorder Blog bot DAX Blogs 0 06.02.2014 22:11
atinkerersnotebook: Creating Lifecycle Services Business Process Models with the Task Recorder Blog bot DAX Blogs 0 08.12.2013 19:12
tlefor: Dynamics AX2012: Integrating Managed Controls with Task Recorder Blog bot DAX Blogs 0 28.10.2013 10:11
Часовой пояс GMT +3, время: 20:42.
