Старый 14.10.2016, 01:11   #1
organicax: Route re-use for multiple products
Источник: https://organicax.com/2016/10/13/rou...iple-products/
When you are setting up your routes you need to consider a lot of things like how you want to use the data for scheduling, costing etc. If you compile all this data and look for similarities then you could for example setup one route that multiple products could go through.
While you might make a different product, the production steps might be the same. In AX this can save you setup and administration of data because you can setup a route and relate it to multiple SKUs.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: Route feasibility error when resource not setup correctly Blog bot DAX Blogs 0 12.10.2016 19:12
organicax: Operation at different steps in a route with different resources Blog bot DAX Blogs 0 30.09.2016 22:13
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
DynamicsAxSCM: Using route schedules in TMS with CU10 Blog bot DAX Blogs 0 11.12.2015 17:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Часовой пояс GMT +3, время: 02:28.
