Старый 17.09.2016, 21:14   #1
organicax: Counting group – Counting Code – Zero in stock
Источник: https://organicax.com/2016/09/17/cou...zero-in-stock/
If you are working out a strategy for counting inventory in AX. One of the tactics for an item might be to count it when it reaches zero inventory. In theory it would be the easiest to count as you would just need to look for the item and see if you come across any in the warehouse. It might not work for high turn over products where you are likely moving inventory in and out and not getting to zero often.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Supply chain planning, Warehouse management
organicax: Buyer group on the planned order Blog bot DAX Blogs 0 17.09.2016 01:16
organicax: Assigning a WMS work template to a disposition code Blog bot DAX Blogs 0 10.05.2016 10:11
Поставщик Учетная Группа anatol33 NAV: Программирование 9 25.05.2009 22:17
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 13:05.
