Старый 07.09.2016, 09:11   #1
organicax: Lean scheduling group – color
Источник: https://organicax.com/2016/09/06/lea...g-group-color/
If you are working with the lean scheduling board you might want to look at using color on your items to differentiate them for different reasons. You can do this with the lean scheduling group.
As you will see in the video, if you need to change the colors you might want to experiment with when they take effect.
Here is a quick overview.
AX2012 R3 Cu11.
Cheers
Lachlan
Filed under: Production control
german_nav_developer: Catch Me If You Can – try-catch für .NET in C/AL Blog bot Dynamics CRM: Blogs 0 22.09.2014 11:00
dynamics-coe: Integrating Microsoft Dynamics CRM 2011 Online with Java and other non-.Net Clients Blog bot Dynamics CRM: Blogs 0 21.09.2013 13:11
Nav developer: Table Information including Index information (Usage, Blocks and Reads) Blog bot Dynamics CRM: Blogs 0 25.08.2009 19:34
NAV Sustained Engineering Team Blog: Index Usage Query Blog bot Dynamics CRM: Blogs 0 26.02.2008 12:29
Часовой пояс GMT +3, время: 13:12.
