Старый 27.06.2016, 00:19   #1
Kashperuk Ivan: Walkthrough: Processing of inbound ASNs in Warehouse Management in AX '7'
Источник: http://kashperuk.blogspot.com/2016/0...ound-asns.html
IntroductionA while back I posted a blog post explaining how to configure and process incoming ASN documents in AX 2012 R3. You can find it here.With the release of the new Dynamics AX version, it was time for an update, since the implementation changed completely, even though the data model behind stayed the same.If you are interested in inbound ASNs, you have a number of options below to
DynamicsAxSCM: Improve performance by running the Warehouse management on-hand entries cleanup job – for New AX and for AX2012 R3 CU10 Blog bot DAX Blogs 0 13.01.2016 11:11
emeadaxsupport: Checklist of setup and configuration items for getting Input Location from Resource assigned with Put work in Raw material picking with Warehouse Management processing in AX 2012 Blog bot DAX Blogs 0 12.08.2015 20:17
Kashperuk Ivan: Tutorial: Short pick goods on the mobile device in Warehouse management module of Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 23.07.2015 00:12
emeadaxsupport: How to print BOL from Transportation Management without using Warehouse Management Blog bot DAX Blogs 0 12.03.2015 18:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
Часовой пояс GMT +3, время: 21:08.
