Старый 20.05.2016, 15:11   #1
emeadaxsupport: Compatibility statements – Patching the kernel only is not enough – you have to patch the application
Источник: https://blogs.msdn.microsoft.com/axs...e-application/
From time to time we see questions about the compatibility statements and what they mean. The most common question relates to whether they apply to the kernel or the application. A common misconception is that you only need to patch the kernel rather than the application. This is not the case. For example, If the... Read more
hotfix, kernel, как правильно
emeadaxsupport: FAQ: Microsoft Dynamics AX Kernel Hotfixes Blog bot DAX Blogs 0 12.12.2014 00:11
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics 5.0 Service Pack 1 Blog bot Dynamics CRM: Blogs 0 04.06.2010 12:51
Права на добавление объектов в Дизайнере Cyr NAV: Администрирование 10 13.06.2009 21:27
Часовой пояс GMT +3, время: 14:39.
