Старый 25.01.2013, 16:48   #1
Windows PowerShell is becoming ever more used in the professional IT organization, and in Microsoft Dynamics NAV we are continuously extending and improving the set of administration management PowerShell cmdlets.
With hotfix 2791548, we introduce these additions and updates, all fully backward compatible with cmdlets shipped with Microsoft Dynamics NAV 2013:
  • New-NAVServerInstance
    • Creates a new Microsoft Dynamics NAV Server instance - new parameters
  • New-NAVWebServerInstance
    • Creates a new Microsoft Dynamics NAV Web Server instance and binds this instance to a Microsoft Dynamics NAV Server instance - new
  • New-NAVDatabase
    • Creates a new Microsoft Dynamics NAV database from a backup file - new
  • Rename-NAVCompany
    • Renames a company in a Microsoft Dynamics NAV database - new
Note
To use the new and changed cmdlets, you must obtain the relevant hotfix through your Microsoft Dynamics NAV support contact. For more information, see the KnowledgeBase article for the hotfix (requires access to PartnerSource/CustomerSource).
The rest of this blog post describes the cmdlets at a summary level. The full documentation is available on the MSDN Library. Additional documentation is available at Microsoft Dynamics NAV Windows PowerShell Cmdlets.
Creates a new Microsoft Dynamics NAV Server instance.
Syntax
Parameter Set: __AllParameterSets
New-NAVServerInstance [-ServerInstance] <String> -ManagementServicesPort <ServicePort> [-ClientServicesCertificateThumbprint <String> ] [-ClientServicesCredentialType <String> ] [-ClientServicesPort <ServicePort> ] [-DatabaseInstance <String> ] [-DatabaseName <String> ] [-DatabaseServer <String> ] [-ODataServicesPort <ServicePort> ] [-ServiceAccount {<LocalService> | <NetworkService> | <LocalSystem> | <User>} ] [-ServiceAccountCredential <PSCredential> ] [-SOAPServicesPort <ServicePort> ] [ <CommonParameters>]
Detailed Description
Use the New-NAVServerInstance cmdlet to create a new Microsoft Dynamics NAV Server instance. You must specify a name for the instance, in addition to values for the four port parameters. All other configuration values for the new instance are based on default values. Make sure that you verify the DatabaseServer and DatabaseName values after the instance is created, to ensure that the instance can accept client requests.
All permissions that are required for the instance to start are configured automatically.
See Also
For more information, see New-NAVServerInstance on the MSDN Library.
Examples
Example 1
This example creates a new Microsoft Dynamics NAV Server instance. It configures the necessary firewall exceptions and performs the necessary Access Control List registrations.
// Copyright &copy; Microsoft Corporation. All Rights Reserved.
// This code released under the terms of the
// Microsoft Public License (MS-PL,
http://opensource.org/licenses/ms-pl.html.)
C:PS>New-NAVServerInstance NewInstance -ManagementServicesPort 8099 -ClientServicesPort 8100 -SOAPServicesPort 8101 -ODataServicesPort 8102 &ndash;verbose
VERBOSE: NavCommand.BeginProcessing
VERBOSE: NavCommand.ProcessRecord
VERBOSE: Creating Instance directory C:Program Files (x86)Microsoft Dynamics NAV70ServiceInstancesNewInstance
VERBOSE: Adding Windows Firewall (and UrlAcl) rules for Server Instance MicrosoftDynamicsNavServer$NewNAVServer
VERBOSE: NavCommand.EndProcessing
Example 2
This example prompts for ServiceAccount credentials and then creates a new Microsoft Dynamics NAV Server instance.
// Microsoft Public License (MS-PL, http://opensource.org/licenses/ms-pl.html.)
C:PS>Get-Credential | New-NAVServerInstance NewInstance -ServiceAccount User -ManagementServicesPort 8099 -ClientServicesPort 8100 -SOAPServicesPort 8101 -ODataServicesPort 8102 &ndash;verbose
Creates a new Microsoft Dynamics NAV Web Server instance and binds this instance to a Microsoft Dynamics NAV Server instance.
Syntax
Parameter Set: Default
New-NAVWebServerInstance -Server <String> -ServerInstance <String> -WebServerInstance <String> [-ClientServicesCredentialType <String> ] [-ClientServicesPort <String> ] [-DnsIdentity <String> ] [ <CommonParameters>]
Use the New-NAVWebServerInstance cmdlet to create a new Microsoft Dynamics NAV Web Server instance and bind this instance to a Microsoft Dynamics NAV Server instance on the same computer or on a remote
computer. If you call this cmdlet multiple times then multiple instances of the Microsoft Dynamics NAV Web Server are created. Each instance of the Microsoft Dynamics NAV Web Server is created as an IIS Web application under a generic Microsoft Dynamics NAV Web Server web site.
See Also
For more information, see New-NAVWebServerInstance on the MSDN Library.
New-NAVDatabase
Creates a new Microsoft Dynamics NAV database from a backup file.
Syntax
New-NAVDatabase [-FilePath] <String> -DatabaseName <String> [-DatabaseInstance <String> ] [-DatabaseServer <String> ] [-Force] [-ServiceAccount <String> ] [ <CommonParameters>]
Parameter Set: MultipleDestinations
New-NAVDatabase [-FilePath] <String> -DatabaseName <String> -DataFilesDestinationPath <String> -LogFilesDestinationPath <String> [-DatabaseInstance <String> ] [-DatabaseServer <String> ] [-Force] [-ServiceAccount <String> ] [ <CommonParameters>]
Parameter Set: SingleDestination
New-NAVDatabase [-FilePath] <String> -DatabaseName <String> -DestinationPath <String> [-DatabaseInstance <String> ] [-DatabaseServer <String> ] [-Force] [-ServiceAccount <String> ] [ <CommonParameters>]
Use the New-NAVDatabase cmdlet to restore a database from a backup file. You can specify the location of transaction log files and data files.
You can use this cmdlet to restore a database to a remote SQL Server instance or to a SQL Server instance that is running on the same computer on which you run the cmdlet.
See Also
For more information, see New-NAVDatabase on the MSDN Library.
Examples
Example 1
This example restores a database and preserves the original file names and locations.
New-NAVDatabase C:Backupsbackup1.bak &ndash;DatabaseName NewDatabase &ndash;Verbose | fl
VERBOSE: Restoring database 'NewDatabase' from backup file: 'C:Backupsbackup1.bak'...
VERBOSE: Restore of database 'NewDatabase' from file 'C:Backupsbackup1.bak' has been completed successfully.
DatabaseName : NewDatabase
DatabaseInstance : MSSQLSERVER
DatabaseServer : server1.cronus.com
Example 2
This example restores a database, moves transaction log files and data files to the new location 'C:newdestination', and preserves the original file names.
New-NAVDatabase C:Backupsbackup.bak -DestinationPath c:newdestination -DatabaseName NewDatabase &ndash;Verbose
VERBOSE: Restoring database 'NewDatabase' from backup file: 'C:Backupsbackup.bak'...
VERBOSE: Restore of database 'NewDatabase' from file 'C:Backupsbackup.bak' has been completed successfully.
DatabaseName DatabaseInstance DatabaseServer
NewDatabase MSSQLSERVER server1.cronus.com
Rename-NAVCompany
Renames a company in a Microsoft Dynamics NAV database.
Syntax
Rename-NAVCompany -CompanyName <String> -DatabaseName <String> -NewCompanyName <String> [-DatabaseInstance <String> ] [-DatabaseServer <String> ] [-ErrorLogFileName <String> ] [ <CommonParameters>]
Use the Rename-NAVCompany cmdlet to rename a company in a Microsoft Dynamics NAV database.
See Also
For more information, see <a title="Rename-NAVCompany" href="http://go.microsoft.com/fwlink/?LinkId=279853" target="_blank">Rename-NAVCompany on the MSDN Library.
Examples
Example 1
This example renames the company Cronus Ltd. in the Cronus database to MyCompany.
Rename-NAVCompany -DatabaseName Cronus -CompanyName "Cronus Ltd." -NewCompanyName MyCompany &ndash;Verbose
VERBOSE: Renaming company 'Cronus Ltd.' to 'MyCompany' ...
VERBOSE: Renaming of company 'Cronus Ltd.' to 'MyCompany' has completed successfully.
Example 2
This example renames the company Cronus Ltd. in the Cronus database to MyCompany. Errors are logged to the file C:NavDatabasesErrorLog.txt.
Rename-NAVCompany -DatabaseName Cronus -CompanyName "Cronus Ltd." -NewCompanyName MyCompany -ErrorLogFileName C:NavDatabasesErrorLog.txt
- Morten Jensen and the rest of the Microsoft Dynamics NAV Management Tools team
Источник: http://feedproxy.google.com/~r/Micro...n-cmdlets.aspx
Часовой пояс GMT +3, время: 15:12.
