Старый 28.09.2012, 14:51   #1
In Microsoft Dynamics NAV 2013 it is supported (and default value) to use text variables without a length.(not fields!)
just my 2 cents:
Because of this it could be possible to use a workaround for a “memo field” without an add-in.
1. Just create a page (or use an existing one) with a text variable without a length.
2. Use the variable instead of a field directly in the page.
3. Set some properties about the look and feel (like width) and …
voila’ “a memo control”
All you have to do now is add some code for storing the data in a blob (in the table) and
- reload it when you get the record or
- save it (you can use an action for this) when you want to change it.
Of course no text formatting options are available.
/Rene
Далее
Часовой пояс GMT +3, время: 07:58.
