Старый 17.01.2012, 18:54   #1
Our example is a simple requirement:
To prevent a user posting purchase invoices headlong he has to enter manually the total amount of the invoice lines in a field on the invoice header and only when header amount and lines total match can the document be posted.
This feature might ring a bell for those of you working with NAV BE and NL as it's part of the standard NAV BE/NL application. However, for brevity sake, we will not take into account all the details of the BE/NL requirements.
So let's make up our initial version of the Test List based on the above requirements:
Description
1
Create PI (purchase invoice) with 1 line and check that total line amount is calculated right
2
Create PI with multiple (2) lines and check that total line amount is calculated right
3
Create PI with multiple lines and check that doc. amount verification succeeds
4
Create PI with multiple lines and check that doc. amount verification fails
Note that, while moving forward, the list might grow as we might stumble across some additional issues, but for now it seems a sufficient list, so let's go ...
... shortly after the following.
To be able to make use of the NAV testability features in it's full extend we need to:
  1. 'turn' them on, and
  2. import the various test libraries provided by MS
Turn on Testability Features
  1. Open NAV 2009 classic client
  2. Select Tools > Options ...
  3. Set the Show C/AL Testability properties value to Yes
Import Test Libraries
Get the Application Test Toolset for Microsoft Dynamics NAV 2009 SP1 here and import the .fob.
Finally we are set and can go.
Notes
NAV testability features have been introduced in NAV 2009 SP1 so you will need to use NAV 2009 SP1 or higher.
Читать дальше
Часовой пояс GMT +3, время: 11:23.
