Старый 05.03.2008, 13:24   #1
SDauren is offline
SDauren
[Всем привет!
Возникла досадная ошибка.
При нажатии на кнопку сохранить (в строках), которая находится на веб-части "заголовок - строка" для каждой строки, выходит ошибка:
Server Error in '/' Application.
Input string was not in a correct format.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.FormatException: Input string was not in a correct format.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[FormatException: Input string was not in a correct format.]
System.Number.ParseDecimal(String s, NumberStyles style, NumberFormatInfo info) +0
System.Decimal.Parse(String s, NumberStyles style, IFormatProvider provider) +30
System.Convert.ToDecimal(String value, IFormatProvider provider) +63
Microsoft.Navision.EmployeePortal.WebPartLibrary.Utility.DecimalTools.GetDecimal
ValueInvariantCulture(String decimalAsString) +75
Microsoft.Navision.EmployeePortal.WebPartLibrary.Utility.List.DataSetTools.GetDa
taSectionForLine(BasePart webPart, DataSet ds, DataTable unmodifiedData, Boolean onlyFromDataSet, Int32 selectedLine) +711
Microsoft.Navision.EmployeePortal.WebPartLibrary.CombiPart.Action_Command(Object o, CommandEventArgs e) +3515
System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +110
System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePo
stBackEvent(String eventArgument) +115
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +138
System.Web.UI.Page.ProcessRequestMain() +1281
Version Information: Microsoft .NET Framework Version:1.1.4322.918; ASP.NET Version:1.1.4322.919
Кто нидь встречался с такой проблемой?
Помогите пожалуйста.
Старый 06.03.2008, 13:02   #2
satir is offline
satir
Аватар для satir
77 / 10 (1) +
Маленькая просьба - пользуйтесь словарем, не засоряйте форум.
Часовой пояс GMT +3, время: 13:50.
