#1 |
The Application Benchmark Tool has been developed to measure the performance of a Navision installation, and to express the results in terms that mirror real world situations.Ideally, these results should relate directly to the terms of a requirement specification from a customer. The tool can be used when you are running Navision on either Navision Database Server or on SQL Server. The tool puts a realistic load on the server in order to monitor the true performance of Navision.
The Application Benchmark Tool version 1.00 is developed for Microsoft Business Solutions-Navision W1 4.0 and Microsoft Navision W1 3.70A. Important: The tool should only be used in a test environment. http://www.mibuso.com/dl.asp?FileID=396&Type=file
