Старый 31.03.2016, 10:11   #1
palleagermark: Check out all several languages of a label file in one process in AX 2012
Источник: http://www.agermark.com/2016/03/chec...guages-of.html
If you work under version control and you update labels in more than one language, you might have found it cumbersome that you for each language need to switch language in the label dialog and then check each language out individually.
I have made a job that does this in one process. The job uses saved selections from the label dialog to figure out the label file to check out, and in which languages.
Use at your own risk.
emeadaxsupport: Positive Pay Setup in AX 2012 R2 Blog bot DAX Blogs 0 24.06.2014 23:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: AX for Retail 2012 R2: Installing the Real-time Service Blog bot DAX Blogs 0 19.12.2012 11:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: Error in upgrade readiness check when upgrading to AX 2012 Blog bot DAX Blogs 0 11.11.2011 14:11
Часовой пояс GMT +3, время: 16:31.
