Старый 14.03.2016, 02:40   #1
organicax: Setting up modes of delivery on a call center
Источник: http://organicax.com/2016/03/13/sett...a-call-center/
If you are setting up a new call center then you have to setup modes of delivery. But it’s a little different process compared to most reference data setup in AX. You first have to create them in sales and marketing and allow them to be used on your new call center. But for them to be active on the call center then you will have to run a periodic process.
Here is a quick look.
AX2012 R3 CU9
I noted in the video here this is Cu9 because the steps changed in CU9.
Cheers
Lachlan
Filed under: Retail
organicax: Creating a coupon for a discount and using on a call center sales order Blog bot DAX Blogs 0 11.03.2016 05:17
organicax: Enable price control on a call center Blog bot DAX Blogs 0 09.03.2016 03:28
atinkerersnotebook: Configuring Automatic Freight Charges Based On Modes Of Delivery Blog bot DAX Blogs 0 21.09.2015 15:11
emeadaxsupport: AX for Retail R3 CU8 Call Center: Fix for Customizing CRT Pricing Engine Blog bot DAX Blogs 0 01.07.2015 19:11
emeadaxsupport: Enabling the new Call Center Channel User Functionality in AX 2012 R3 Blog bot DAX Blogs 0 02.09.2014 18:11
Часовой пояс GMT +3, время: 02:52.
